When you start by digesting a tv-section, you (or @ least I would) start with the following:
http://PMS:32400/library/metadata/116/allLeaves
Above would return information about the tv-show with the key of 116, like:
Then you would go into the individual episodes....
But.....and here's the Req....
I miss information, that can be retrieved by sending a req like:
http://qnap2:32400/library/metadata/116
Note the missing /allLeaves from that url!!!
above will return:
As you can clearly see from above, there's a lot more info, and I would hate to issue yet another req. towards PMS to get to that info if I could avoid it....
So.....
Any chance that the /allLeaves could return above as well ?
This would indeed speed up things, when/if I wanted to export the "label" field into a CVS file
Best Regards
Tommy
