Where
I wrote a little crawler that scans my preferred P2P site, checks (according to keywords) if a show is available and downloads it.
But before downloading I would like to check if that episode already exists in my PMS library.
So I thought I would find the information in the XML response given by querying "localhost:32400/library/metadata/5442/allLeaves" (note : 5442 is the id of the show) but no season/episode information here...
Any idea where it might be ?
Thanks.
M.
Not sure, if this is the right information - but sure it looks like:
You got to start earlier... when selecting the actual show you get a menu like
 - All episodes
 - Season 4
 - Season 5
or in XML (cleaned up for easier reading):
<Directory [...] title="All episodes"/>
<Directory [...] type="season" title="Season 4" [...] index="4" [...]>
<Directory [...] type="season" title="Season 5" [...] index="5" [...]>
Look at the index-tag an remember the content - this should be your Season ID.
Diving into one of the seasons you get something like...
again in XML:
<Video [...] title="" [...] index="1" [...]>
<Media id="..." [...]>
<Part id="..." [...]/>
<Video [...] title="" [...] index="2" [...]>
Again, search for the index-tag an remember the content - this should be your Episode ID.
Please check this data against some of your shows, it seems to fit in my library. I just cannot guarantee it's the same on your side :-)
Thanks for your reply Baa.
I searched the higher branches in the library tree but could not get any XML output with :
What url do you query to get this ?
In my example: starting at...
http://127.0.0.1:32400
climb down the "key"s:
/library/sections/2/all
from there you will be kind of redirected with key=
/library/metadata/37/children
to the view like described. For sure the "2", "37", "children" are only keywords valid in my database - they would different on you machine. Also, the Season/Episode view only comes up when using a TVShow scanner, a Movie has different metadata.
Thank you so much Baa.
I must have been blind !!! :-)
