Server Version#: 1.24.1.4931, 1.24.2.4973
After I upgraded from 1.24.1.4930 from 1.24.1.4931, server setting is totally unavailable, so I went back to 1.24.0.4930 and stick there for a while.
Today I see new version 1.24.2.4973 came out, so I upgraded to this new version, and the issue still exist.
Please let me know if any logs would help.
Thanks.
Hi, with no response, I managed to find the root cause myself.
I tried to run start.sh manually, then it said
ImportError: Shared object “libxml2.so.2.9.10” not found, required by “etree.so”
I checked the uncompressed source directory, the file is there, but can’t be found by Plex.
After manually copying the file to /usr/local/lib/ , latest version of Plex Media Server (1.24.3.5033) seems to be running fine on FreeBSD.
Hope you can fix this as soon as possible.
Thank you.
