Hello, all. This is my first time posting here. I just received my RPi B+ the other day, and flashed Rasplex on my MicroSD using rc4, and was having issues, but then found out about rc5, so I flashed that. But now when I go to "check for updates," it finds rc4 and attempts to "update" to that lower version. Is this a mistake? Not sure if I'm the only one, but I haven't seen any other threads about it. Thanks.
If you check the posting about the release in this forum you will notice that this update cannot be installed within Rasplex, you have to download and flash to your microSD card.
Regards
That's exactly what I did. However, the automatic update once I'm already on rc5 attempts to update me to rc4.
Go into preferences and turn off Auto Update, make sure channel is set to Stable.
It shouldn't do this, please file an issue on Github.
Regards
