I may be in the wrong place here, so apologies, but here goes;
I'm playing a lot of 1080p and 720p material, I don't know lot of detail about the video, but its generally DTS 5.1 audio, and all wrapped as an MKV file.
I get smooth playback on Rasplex, but sometimes the video abruptly stops. If I set transcode to 20Mbps rather than direct play, it is far, far more reliable. I notice on my plex server that the video is still direct play, but the audio seems to be transcoded / down-mixed to PCM ?
Is there a way to preserve the DTS digital audio, or perhaps convert to DD 5.1? Anything other than PCM?
I dont know why setting to 20mbps is fixing the reliability, even though it is direct stream video, but it is. It seems in "busy" scenes, presumably very high bitrate sections of video, it bombs out, and drops me back to the movie art, although there doesn't always seem to be a reason why.
Is the video being re-packaged into something more compatible by forcing transcode? Can I still get DTS or DD audio direct ?
Are you just just using your TV speakers or do you have the pi connected through an AV Receiver ?
If its the latter have you enabled DTS and AC3 passthrough in the preferences in RasPlex ?
