RTMP Stream, sound working, not video!
I’m working on a plugin for http://www.tou.tv (a French Canadian webtv site)…
So far, everything is working (I am able to retrieve the show list, the episodes etc…), but when I get to the part where the video should be playing, I’m only getting sound and a black screen!
Here’s the relevant part of code (GetEmissionList retrieves the list of episodes for a serie, GetVideo delivers the actual video)
<br />
def GetEmissionsList(sender, url):<br />
    dir = MediaContainer(title2=sender.itemTitle)<br />
    page = XML.ElementFromURL(url, True)<br />
    for item in page.xpath('//div[@class="blocepisodeemission"]'):<br />
        try:<br />
            saison = item.xpath('.//p[@class="saison"]')[0].text<br />
            episodeurl = item.xpath('.//a[@class="episode"]')[0].get('href')<br />
            title = saison + ": " + item.xpath('.//a[@class="episode"]/b')[0].text<br />
            dir.Append(Function(WebVideoItem(GetVideo, title=title), url=TOUTV_URL + episodeurl))<br />
        except IndexError:<br />
            continue<br />
    return dir<br />
<br />
<br />
def GetVideo(sender, url):<br />
    # first, try to find the episode id!<br />
    page = HTTP.Request(url)<br />
    clip = re.search("\"pid\":\"([^\"]+)\"", page).group(1)<br />
    # request the info from ThePlatform...<br />
    platformurl = "http://release.theplatform.com/content.select?pid=" + clip<br />
    platformpage = XML.ElementFromURL(platformurl, True).xpath('//playlist/choice/url')[0]<br />
    # split the url so we have the media url in [0] and the clip in [1]<br />
    platforminfo = platformpage.text.split("<break>")<br />
    return Redirect(RTMPVideoItem(platforminfo[0], clip=platforminfo[1], width=852, height=480))<br />
Am I doing anything wrong? Considering the sound is working, I know I am parsing the URL correctly etc... I just can't get the video to work!
I have no idea if it's relevant, but the video should be an mp4... (the "clip" parameter looks like this: mp4:002/MOV/HR/2010-08-24_BEAUTES_0134_hr.mov)
Any help would be appreciated!
Just a quick add-on to my previous post, it appears my plugin might not be the only one suffering from this issue. I tried installing the “Canal +” plugin from Plex Online, and most of the video there have the same issue, i.e. Sound, but no video!
The problem is probably your Flash player. Do you have version 10.1? 10.1 doesn’t work yet with Plex (8 and 9). If you do have 10.1, uninstall it and install version 10.0.x
More info on this: http://forums.plexapp.com/index.php?/topic/15088-audio-but-no-video-with-plugins/
Wasn't aware of that! Thanks for the info! Will try again with an older flash version!
Je veux ce tellement plugin! :slight_smile:
Je suis prêt à donner un coup de main pour le terminer s’il le faut!
Sam
Here you go TOU.TV Plex Plugin
Enjoy ! :slight_smile:
