Running in the background
Hi all
I have PlexConnect running beautifully on Windows Home Server (Win 7) however I would like to run it the background without the python window.
I did a little research and found by renaming or copying the "PlexConnect.py" to "PlexConnect.pyw" and running the .pyw file should do the trick.
However once I do this the "pythonw.exe" jumps up in my Task manager processes tab and then quickly dies a few seconds later.
Is this something i'm doing wrong or a bug that i should submit?
Cheers
Hm... bug report won't help much, I guess.
I have no idea what "pythonw" is or does.
Currently I don't see this as a bug, as you run it way beyond specifications... :-D
There are better ways to run it in the background if you search the forum e.g covert to a ghost .exe.
See the following thread (last few posts):
http://forums.plexapp.com/index.php/topic/71220-linux-install-for-plex-connect/?hl=%2Brun+%2Bplexconnect+%2Bbackground#entry411924
Not so difficult to fix...
