Server Version#:
In “other Videos” if you set your sortorder to files, there is no videoplayer symbol in the right upper corner, which allows you normaly to play one title after another or skip a title. Previously it worked, but after I reinstalled the app on the samsung Tv it didn´t work anymore and after I had the updated Version for the desktop 8installed 15.04.2024). I have the same issue. But there is no need for me anymore to use plex, if I can´t see my musicvideos one after another, which I put in files.
