Scan multiple libraries simultaneously?
Is there a way to configure Plex to scan and update multiple libraries simultaneously? I’m trying to add my Music collection to Plex, so I can use it in Sonos, and it’s quite large. The issue I now have is that it won’t update any other library until that’s finished, which means it could take a number of days possibly (judging from the slow speed it’s scanning the Music library) before my TV library etc gets re-scanned?
Can the update engine be configured for multiple threads so I can scan multiple libraries at the same time?
Thanks :slight_smile:
By the same token, I’d like to be able to choose which specific library to update instead of it doing all of them by default. If I haven’t added anything to a specific library, I’d rather it not waste my time and it’s updating a library that doesn’t need it. Is this possible and I’m just not seeing it? My desktop app just says “Update libraries”, plural.
Thank you.
I’d like to know this too.
I found out that you can trigger scans from the command-line and it seems it doesn’t mind starting multiple scans.
