I have a library with 650 movies. When I add a new movie it does not show up on “recently added”, but it always the same Jason Bourne movie that show up. I have eveen look at the XML file at the “addedad” date is correct on the new one. But everytime I scan the jason Bourne movie “addedad” get update.
i have other library with movie and they work.
I have tried:
move file out of folder and back in
delete whole library and made a brand new one at rescanned.
No, you can run the script on most platforms – they’re listed on the page… the regular script works on most Linux / Mac based platforms and there’s a dedicated version for Windows.
The page also lists examples how to run it on specific platforms.
It will work on MacOS otherwise I wouldnt have suggested it, see the section labeled: Using DBRepair from the command line on MacOS and the recommended options higher up on the page.
