Server Version#: Version 1.16.2.1297
I noticed this a couple of days ago after the previous beta release and confirmed it is still true after today’s update.
I noticed the library scanner wasn’t picking up some of my new files. After a decent amount of troubleshooting, I realized it was only scanning the first folder no matter where it was located (local vs NAS).
I was able to replicate by creating a new library and adding a single folder. It scanned everything correctly. I added a second folder that was located on the same drive and it completely ignored it. This was true for Movie and TV libraries in my testing.
Anyone using libraries with a single folder would never notice this, but anyone like me that use multiple folders across multiple drives would notice right away.
Figured out what it was:
The previous beta upgrade corrupted the DB. After digging into the scanner log I found the following error:
sqlite3_statement_backend::loadRS: database disk image is malformed
When googling I found this post from 2015:
In which don.alcombright stated:
" So this happened to me a few weeks ago going from one beta to another in unRAID. The fix had nothing to do with my library. I deleted the below two files (with Plex off) and on restart Plex regenerates these:
com.plexapp.plugins.library.db-wal
com.plexapp.plugins.library.db-shm
Your library is not stored in either of these but in this: com.plexapp.plugins.library.db"
It forced me to go find these files on the Mac and found them here (hidden directory which you will need to unhide):
/Library/Application Support/Plex Media Server/Plug-in Support/Databases/
I did not find the 2 files referenced in the 2015 post but I did find the db and backups taken before each upgrade:
com.plexapp.plugins.library.db-2019-06-28
So I stopped Plex renamed the current db file and made a copy of the backup and renamed it as if it was the current db file. I restarted Plex and everything started working again and everything scanning correctly.
I hope this helps anyone who runs into this issue in the future. I should start optimizing my db and backing it up on a regular basis and recommend that for everyone.
