For those of us that have several recording sources and lots of scheduled recordings, the ‘scheduled recordings’ pane on the right side of the screen provides somewhat limited management capability. The only option is to ‘drag and drop’ items to set priority order. If you have 50 or 60 scheduled recordings and you’ve added a new show, it comes up at the bottom of the list at first. To put it to the top of the priority list is very difficult. Only 8 or 10 programs show on the real estate of the screen at any one time, so you have to drag and drop from bottom to top of the visible list over and over (and over) to get it to the top of the list.
I would request that either there be a way to get to an expanded screen with a table or condensed list where most or all of the scheduled programs can be seen at once, or that that when you drag an item to the top or bottom of the list and hover, the list scrolls up or down accordingly. Right now, when you drag to the top of the list, hold the item and hover, the list does not take the cue and scroll.
I’ve had to do dozens of drags and drops many times to get my items from the bottom or middle to the top of the list.
Thanks!
