Easier managment of recording priority
Possibly display up and down arrows.
Add a "move to top ", “Move to bottom” , “Move down” . “Move up” buttons next to the title.
Also add an option at the top to switch to a check box view similar to how it is on android phones when you are selecting multiple files.
This would make manual list cleanup a lot easier.
Thanks!
-Casey
I would like this or even to move the RECORDING PRIORITY list to a separate page entirely away from the Recordings schedule page. It’s wayyy too hard trying to drag shows up and down into places you want them in priority as-is now. PLEASE FIX THIS PLEX A.S.A.P.!!!
Maybe let users assign a priority to the recordings, have a one button cancel, and an option to auto-remove movies from the que once they have recorded.
priority numbers would also be nice for quick movements to a far away priority level (e.g. the last recording you’ve added automatically gets the lowest priority, but if you want to move it somewhere toward the middle of a, say, 150 item list, it would be nice to just write in 75 to get you closer to where you want to be instead of dragging/dropping). the drag/drop re-ordering doesn’t work all that well (e.g. can’t do a continuous scroll down/up if you want to move a recording priority substantially far from where it currently is).
SharePoint has a numerical selection for column order, it would seem easy to me to make this on plex.
Trying to move around 50+ items in a visual list is ridiculous.
Keep the visual list if you want, but i’d like to see a text-based one myself. I can read.
[ShowName] ([Initial Release Year]) - [upcoming airings] | [[editable Priority#]]
'>>on number change, shift list sequencing from number edited by user
PS/Related: why does my priority list show several of the same show? (only one of the duplicates shows upcoming airings)
Thank you
