Script to Auto Update Plex on Synology nas [rev6]
Thanks for your script, it works great!!!
Hallo everyone,
I have the script working but i want the notificatie through telegram i have a bot ready but i dont no how to change it in the script maby someone can help me ?
After the line “/usr/syno/bin/synopkg install /volume1/tmp/plex/*.spk”
put your telegram alert command like this
msg=“New Plex ver installed”
curl -s -X POST “https://api.telegram.org/botYOURBOTKEYHERE/sendMessage?chat_id=-1001263961125&text=$messaggio
Cowboy,
I ended up having to have my run script as
./update-plex.sh --plex-pass
Thank you for the script, I was really hating the manual updates.
Hi there @Martino, the script has been working fine for the past few months but it has stopped recently. This is the output I get:
Task: Plex Update
Start time: Fri, 12 Jun 2020 17:57:00 GMT
Stop time: Fri, 12 Jun 2020 17:57:54 GMT
Current status: 0 (Normal)
Standard output/error:
New Ver: 1.19.4.2935-79e214ead
Cur Ver: 1.19.4.2902-69560ce1e
New Vers Available
--2020-06-12 17:57:02--  https://downloads.plex.tv/plex-media-server-new/1.19.4.2935-79e214ead/synology/PlexMediaServer-1.19.4.2935-79e214ead-x86_64.spk
Resolving downloads.plex.tv... 104.18.157.41, 104.18.156.41, 2606:4700::6812:9d29, ...
Connecting to downloads.plex.tv|104.18.157.41|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 132270080 (126M) [binary/octet-stream]
Saving to: '/volume1/tmp/plex/PlexMediaServer-1.19.4.2935-79e214ead-x86_64.spk'
    0K .......... .......... .......... .......... ..........  0% 3.56M 35s
    129150K .......... ..........                                 100% 67.2M=15s
2020-06-12 17:57:16 (8.55 MB/s) - '/volume1/tmp/plex/PlexMediaServer-1.19.4.2935-79e214ead-x86_64.spk' saved [132270080/132270080]
Failed to install package /volume1/tmp/plex/PlexMediaServer-1.19.4.2935-79e214ead-x86_64.spk, error = [289]
package Plex Media Server start successfully
It knows there’s an update, it downloads the update, then fails to install it. I have got the Synology Certificate installed in Package Center. Any ideas?
EDIT: Changing the Trust Level to Any publisher in Package Center > Settings resolved it, it seems:
2020-06-12 18:23:21 (8.73 MB/s) - '/volume1/tmp/plex/PlexMediaServer-1.19.4.2935-79e214ead-x86_64.spk' saved [132270080/132270080]
/volume1/tmp/plex/PlexMediaServer-1.19.4.2935-79e214ead-x86_64.spk install successfully
Not a big fan of having the set it as such. Could it be due to me having Plex Pass?
Added to the first post!
Thanks! It’s nice to see it running fine again!
Hi there !
Is it possible to take into account our update program preferences : Public or Beta?
Here is what the url to fetch the beta package looks like (without the token I removed)
https://plex.tv/downloads/latest/5?channel=8&build=linux-x86_64&distro=synology&X-Plex-Token=
Thanks !
@Kynch, you need to change to any publisher if you don’t have the plex certificate installed. if you install the plex certificate you can leave on thrusted publisher.
i agree. i would rather NOT get the BETAs. i prefer the more stable public releases
Indeed. I had the Plex Signing key installed, but for some reason, it had been removed. I’ve reinstalled it and set it back to Synology Inc. and trusted publishers again. Thanks for your input!
I wrote a heavily modified Plex auto-update script initially based on Martino’s script. It addresses your concerns and will download and install the update as per your Public/Beta channel selection in the PMS config general settings. I welcome you to read my announcement posting here:
I specifically added the channel selection functionality inspired by your post here.
not sure why , i have a Plax Pass however i am not running the Beta channel
