Search box in plexamp for Windows and Android not working
Hi, when I use the search bar in plex amp for Windows or Android I always get the message “All that you seek is already within you” and no result is showed:
Even if I’m sure that I’m searching for something that exists:
Please post the Plexamp logs after a search, as there’s almost certainly something weird going on.
Here it is, thanks
Share Debug Logs.zip (125.4 KB)
Your search request is erroring:
Jun 28, 2022 22:29:34.862 [Javascript] INFO - Error loading: get https://xxx.yyy.plex.direct:52400/hubs/search?query=Minis ... HTTP status 404
Only reason I can think of for that is you’re running a very old server version?
No I just missed the latest update, but it’s updated almost weekly.
The server is installed on a qnap and it’s behind the router firewall… maybe the origin of the issue is there!? If I point to the URL you showed from a pc browser I get error 401 Unauthorized…
Maybe it’s a redirection issue?
401 is because you didn’t include a token.
The only other possible reason I see for a 404 is if the Plexamp user doesn’t have access to the library you’re searching. You can try enabling Advanced > Search All Libraries and see if it makes a difference.
I only have 1 user to login, I enabled search all libraries as suggested but got the same problem
@elan other thoughts? I think it’s a Plexamp related problem because search function works well on plex app
i’m really sorry, i’m at a bit of a loss here. i don’t really have an explanation for why you’re seeing that error?
on vacation this week, but if you get a chance, post plexamp logs with matching server logs and i’ll see if anything stands out.
Ok @elan thanks, I attach the logs (i’ve searched for the keyword Ministry)
Plex Media Server Logs_2022-07-10_09-03-55.zip (3.3 MB)
Plexamp.log (62.0 KB)
Hmmm, another guess: You have a weird visibility setting for it, check your library preferences.
@elan yeah! That’s it! However it’s a bit of an odd setting… I’d like to hide Music library from the pinned one in the home page of plex, because for music I use plexamp. Shouldn’t be better to just separate the 2 options? One for visibility in home screen and one for global search?
Anyway, thanks a lot
Can’t you just unpin it on the Plex app?
Glad we figured it out!
