The search bar to have an option to select what you want so you can toggle off different media types or library’s, or have a search bar relative to the library you are in, so if on the home tab then it will search all library’s and servers.
When you have music, tv shows and movies the results can be rather annoying.
2022 clean-up: implemented (option to filter search by media type and option to specify libraries of certain servers / online sources)
