For some reason the search function won’t search through my library anymore, I can see and play my library just fine. The only results I get are podcasts hits.
First I thought it was because I was still on a 1.x release so I updated to 3.0.1 but that didn’t help.
Edit your library,
go to the ‘Advanced’ tab
disable “Hide library from Dashboard”
Thank you! This solution was so easy that I feel stupid now…
Don’t worry, this checkbox started to influence search only recently.
It is changed in new server versions to something more nuanced:
