Search within playlists
Can you add a search box within Playlists that ONLY searches within whatever playlist you’re in?
Sometimes I need to see if I have a certain song within a playlist, and Google Chrome search (CTRL + F) doesn’t work because the playlist doesn’t load more items until you scroll down to the bottom…
I too would like to know about this. When I get up to a pretty big playlist I’m finding it difficult to know what’s actually in there
YES PLEASE!!
As another option, put column headers in the playlist so that we can sort the playlist (i.e. sort a music playlist by artist). Need this feature ASAP please (I’m manually building new playlists from old iTunes playlist I can’t easily tell if I’ve accidentally added a song twice … finding duplicates is painful).
I don’t think it will add duplicates (at least it doesn’t in my experience)…
As a workaround, you might want to check out the Plex2CSV add-in channel. It will allow you to generate a list from your playlists into a .csv file, which you can use to find duplicates, etc.
Would be a nice feature
I’ll second that. A “search within playlist” feature would be very handy.
As the OP mentioned, Ctrl+F doesn’t work. It doesn’t even work if I’ve scrolled to the bottom - it’s so hit & miss as to what it finds and what it doesn’t, and I don’t understand why.
Yes, search would make it easier to manage my play lists. For example, I have a 600+ playlist deleting song 342 take a while to find.
Thank you.
Bumping this as a feature request. I have music playlists with thousands of songs and would like to search the playlist in case I need to remove songs.
I would greatly appreciate this feature as well, please.
Bump for this feature
Yeah this feature is sorely missing. Also, looks like Plex2CSV is discontinued.
+1 for this feature
+1 for this feature for me too (both for music and for video playlists!)
Takes me forever to find a particular movie in my playlist to delete once I’ve watched it.
