yup, but he dident clear me like the others, so my server just booted without those 2 and dident get any further
Stand by, I will remove the cert
server cert revoked.
You may now restart it
shoudl i delete them aswell ? or just restart ?
delete the crt. and certificate in Cache aswell or just restart i ment
restart the server.
PMS will do the rest
(File removed)
i still see the CERT errors tho… but now also a handshake problem?
stop the server
delete whatever is in the caches and cert
start it again.
deleted the Cache folder, fully porpulated now from plex, but crash crash
annnd its back up i think
(File removed)
still cert errors
@ChuckPa
stop the server
rename Library to Library.keep
start the server
setup a TEST (make the friendly name “SandBox”)
Don’t create any sections.
See if cert errors persist in new environment.
If errors persist in a fresh sandbox – it’s not plex.
allrigth will do, but will have to wait until tomorrow, it’s late here in denmark
will keep you posted!
just a thougth, if there’s no cert errors etc in sandbox environment, i hate to loose the “libary’s” i have etc, i just followed move server as plex…tv writes, only a few adjustments like the mac id and ip
never happened before this issue tho
thanks for now
libraries and watch history can be moved
(File removed)
allrigth, woke up from nap, and just did as you asked, stopped server, renamed library to library.keep, started server, named it sandbox, dident create sections, and cert issues are still alive sadly, pulled the logs and attched them here
soo what can cause this issue. SNI error still and cert errors
You have issues with the configuration / networking on your end.
sadly there is nothing any of us can do.
at this point, i’d blow down the entire host,
build a fresh , vanilla, ubuntu – ENTIRELY defaults –
then go again.
If you wish you use BSD, I must step away. I do not support BSD.
bah allrigth
so a new server, new plex install, but can’t i move my data with me? so i dont loose everything?
then move like the guide says, and new name? ofc i will try a “sandbox” first, to see if it’s my network all of sudden
I recently started getting the same warning errors and I am using Windows. So I don’t think it is related to Linux etc.
I’m not sure what is causing them. I am doing some searching here before I create my own thread.
Jan 05, 2021 09:26:49.290 [10576] Warning — [CERT] TLS connection came in with unrecognized plex.direct SNI name '192-168-1-140.1bc98625c713483fa06f3d9b81b7f40c.plex.direct'; using installed plex.direct cert
Jan 05, 2021 09:26:49.331 [10576] Warning — [CERT] TLS connection came in with unrecognized plex.direct SNI name '192-168-1-140.1bc98625c713483fa06f3d9b81b7f40c.plex.direct'; using installed plex.direct cert
Jan 05, 2021 09:26:49.364 [10576] Warning — [CERT] TLS connection came in with unrecognized plex.direct SNI name '192-168-1-140.1bc98625c713483fa06f3d9b81b7f40c.plex.direct'; using installed plex.direct cert
Jan 05, 2021 09:26:49.381 [10576] Warning — [CERT] TLS connection came in with unrecognized plex.direct SNI name '192-168-1-140.1bc98625c713483fa06f3d9b81b7f40c.plex.direct'; using installed plex.direct cert
Jan 05, 2021 09:26:49.403 [10576] Warning — [CERT] TLS connection came in with unrecognized plex.direct SNI name '192-168-1-140.1bc98625c713483fa06f3d9b81b7f40c.plex.direct'; using installed plex.direct cert
funny aint it, the thread i refer to, everyone in that thread had same issue as you and i are experianceing, men because i also was moving server, i had to make new post
alltho problem is the same, CERT TLS thingy… guess we have to wait
