Serie episodes in descending order
Hi
It’s a rather small problem, but still it’s pretty annoying. In my library, my serie episodes are in descending order (10, 9, 8,7 , …) instead of ascending order (1, 2, 3, 4, …). Does anyone know how to fix this?
I attached some images.
Edit your library
go to the ‘Advanced’ tab
select the ‘Episode sorting’ drop down
edit_tv_library
If this is already on ‘Default’, you may have to edit the tv shows themselves, as each one can override the library default individually.
Thank you man! That did it.
