Upgraded library episode order
Server Version#:plexmediaserver-1.25.1.5286-34f965be8.x86_64
Made the mistake of ‘upgrading’ my TV library. Now I have shows out of order. Sonarr has the correct order, TVDB has the correct order, but Plex’s order is all wonky. Did I do something wrong or should I just go back to TVDB? Doesn’t seem to be any alternative ordering from the Plex agent.
If you want specific shows to use a certain episode order, you can simply set it for that particular show (or the entire library).
See:
  • :pencil2: > Advanced > Episode ordering (editing the tv-show item)
  • > Manage Library > Edit...Advanced > Episode ordering (editing the library)
It’s funny there’s Aired order and DVD order, both of which are correct on TVDB but still do not match Plex. I changed to TVDB, then I ended up removing and re-adding the show, and updating again and the order looks correct now. Hopefully it stays that way.
It should.
Side note… you shouldn’t have had to remove/readd your files – refreshing the show’s metadata after changing the episode ordering should have done the trick.
