Series Agent TheMovieDB and Season Overview
is there any possibility to get the season overview/plot from themoviedb agent?
season plot is never loaded - even if available !
thanks, tig
thanks, tig
Hi!
The code that does this is already present, but Plex clients seem to ignore it :(
Hi!
and now? what has to be done?
or do you mean, that the information already will be downloaded, but only the clients won´t display them ?
I think this isn´t correct or there is an error in the code:
I can manually enter this information to the season and the webclient for example displays this!
According to the docs, this is the correct way to set the summary for a season, the same way as to how season posters are set (and that works). I don't know why a manually entered summary works, but the summary set by the agent doesn't. Sounds like a bug.
unfortunately the season images also don´t work properly.
the right image is loaded, but if you edit the seasondetails you can´t select it.
it looks like this:
![post-73674-0-91204500-1414709920.png|688x500](upload://1MTli6kHIKMLqQWBZl5laUYoVMO.png)
if there is more than one season poster you can´t select another one.
if thetvdb also has posters for this series and you have it as second agent, then you can select posters from thetvdb - but not the ones from themoviedb.
maybe these problems are connected?
are you the developer of this agent?
best, tig
any news here?
sander, could you verify the problem with the images as well?
edit: shall I open a ticket for that at github as well ?
