Server certificate reset
Sorry for piggybacking. Would it be possible to reset my certificate? None of my devices can connect securely.
@boooiil it i does look like your server was rate limited trying to get a cert so i reset it. You may need to restart your server
It looks like I’m still getting 429 errors after restarting. Devices still cannot connect securely.
@boooiil I reset it again. if still happening can you please grab the server logs. maybe we can glean why it might be happening.
Attached should be the logs!
it looks like access is being denied to write to the cache directory. so need to fix those permissions
Feb 15, 2023 21:16:20.912 [3088] ERROR - SafelyWriteFile: rename for '"I:\Plex Media Server\Cache\CloudAccountV2.dat.tmp.e0500dc5-3876-44c5-a864-3ac1ceff140f"' failed: Access is denied
I think I resolved the permission issue, seem to still get a 429.
OK. I reset it again. it looks ok now on our end
I have the same issue with Plex media server on the Nvidia Shield Pro.
Can someone reset the certificate (apparently that is the reason I cannot connect from web to the server with insured allowed for same network. My username is fuzzygel
thanks in advance
it appears that just writing this message the magic works. I have been working this for the last 3 days since I received the new Nvidia Shield Pro and kept getting the cannot connect to unsecured connection error.
All of a sudden, when I check from my latptop, it all working. I can connect to my Plex media server on the Shield. I did not know what happened or what has changed
I also like to under how the resetting of certificate can fix some of the issue. I must admit I did not even know about the certificate until I googled and trying to find a solution to fix my earlier issue
another update, after a few days of successful connect, today I get back the error " app.plex.tv is unable to connect to “SHIELD Android TV” securely"
@BigWheel , I need your help on this
thank in advance
Can you access it when going to shieldLocalIP:32400/web ?
thanks @BigWheel for the tip to troubleshooting. When I try to connect I received this error message
I selected "proceed to 192.168.74 (unsafe) but Chrome would proceed
also try http://192.168.50.74:32400/web without https:// but my Chrome browser still would not connect
also try that on Safari , still no go
Click the “proceed” link at the bottom. it is your local server.
I did, as mentioned in previous post #33
sorry. I guess I don’t understand what you see after hitting that link.
It looked fine but I just reset it anyway. You may need to restart device or server
thanks @BigWheel , appreciate that. After rebooting the Shield, everything back to normal now. However, I am still interested to know why it broke after days of working and how certificate is relevant in stopping me accessing the PMS, is there any documentation on certification and on troubleshooting?
Hi. I would really appreciate if my certificate would be reset. completely unable to connect to the server for adding content. been trying to erase all and redo the installation but with no success.
thanks.
I don’t see anything wrong with cert. it is brand new from server created about 2 hours ago.
A cert reset only helps if you are experiencing e 429 error getting a new one.
can you access the server via local IP of shield:32400/web
