If you select Change Subscription the result is server locks/crashes (Windows system). Repeated three times since having issues accessing the Plex.tv account settings (with cloudflare errors) DNS.
Immediate issue found after latest upgrade of plex server app.
Correction: the “lockup” resolves after the DNS error from cloudlfare (and if you wait the server does return without having to crash/reboot). RDS/etc. is unresponsive as well as ping while this takes time to fail. Repeatedly tested and as I said: your server will be accessible after the errors and dns times out eventually. VERY ANNOYING however.
