Hi, I’m running a Plex Media Server on my Centos 7 server on my local network.
Everything went fine, I can access to my files, etc…
But when I try to claim it, it vanish…
When I look into “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Preferences.xml” there is my PlexOnlineUsername set.
I don’t know what I have done wrong, can someon help me ?
I’m sorry ChuckPA, this does not work. I’ve even tried accessing in a totally different browser on a different computer. No luck. Any other help would be appreciated.
I’m having the same issue. I’m running Ubuntu and am having to claim my server multiple times a day. I’ve logged out of the account, logged in, tried different browsers and different computers.
This is new behavior within the last update or two.
I’ve been having the same issue and I can’t seem to figure out a way to solve this.
A quick rundown - I’ve been using Plex on a Synology NAS for quite a long time now. Recently I moved from New Zealand to Australia. Same computers, same router, same settings. I guess the only thing different is the service provider. I checked and I don’t have a double-nat issue. Tried to delete the preferences.xml - didn’t help. The moment I claim the server it disappears and the only way to get it back is to remove the keys related to the “claiming”. Of course then the server is not accessible through internet, only on the local network. Any more ideas would be super appreciated.
Thanks!
Thanks!
Check your DNS and subnet addressing. These are the two most common changes which cause problems whenever moving.
nslookup plex.tv will tell you if the computer is seeing the net correctly. if it’s coming back as ‘unable to resolve’ or other error, you’ve found the problem
Those values verify DNS from computer through 192.168.1.1 is reaching out.
Is the Synology’s networking (Control Panel - Network - Interfaces - each active device) setup for the correct subnet?
Does the one which is connected to the internet also have the Set as default gateway box checked?
Yes and yes.
In a last desperate attempt, I wiped out the whole thing, did a fresh install and now it all seems to be working.
Super annoying because I lost of a lot of manually added data, but at least things seem to be working once more.
Thanks again for all your help!
I seem to be having similar issues with my account. Whenever I remove the claim on server form the configuration I can access it with no user linked to it and immediately when I claim it I get a message that server not found (Cant access any library or server setting).
Any other user using my server has no issues though…
