Server Version#: Latest, Windows
Player Version#: Not Important at this stage
My current Plex Server is a 4th Gen (Haswell) Intel CPU with 8GB of memory living on a old Lenovo Thinkcenter M93p SFF Desktop
Its OK, and has been reliable, but transcoding when required has issues. Direct Stream is fine
A replacement of some kind is in the cards. As I see it there are 2 options.
- A new CPU (higher generation) - to allow hardware transcoding
- Graphics Card - to allow hardware transcoding.
Neither of which, due to PSU limitations / or motherboard limitations are practical in the existing PC.
So I am starting with a new PC of some kind.
I am unsure of the difference / effect of CPU transcoding (hardware) using a newer generation of CPU vs GPU transcoding - which should I be aiming at
What happens if you have both? New CPU & GPU (of an appropriate type) although I imagine I would start with CPU and then upgrade to GPU if needed (ie just make sure that the PC can handle a graphics card later)
I would probably buy a modern m/b with onboard graphics in the first place, and then add a discreet GPU if sensible later on.
Mostly 1080p with some 4K (growing slowly). A lot of H.265 though
3-4 clients only with mostly one or two at any one time.
I have a budget of approx £1,000 - but the less I spend the better.
Any suggestions / comments?
Sean
