Server keep "crashing" since last few beta updates
it was bugging me.
-rw-r--r--  1 chuck chuck   951 Apr 11  2021  Pref.save
-rw-------  1 chuck chuck 12330 Dec 18 02:54 'Setup Plex.html'
drwxr-xr-x  2 chuck chuck  4096 Dec 18 02:35  Updates
chuck@papyplex:/var/lib/plexmediaserver/Plex Media Server$ cd Drivers
chuck@papyplex:/var/lib/plexmediaserver/Plex Media Server/Drivers$ ls
icr-15-linux-x86_64
chuck@papyplex:/var/lib/plexmediaserver/Plex Media Server/Drivers$ ls -la
total 12
drwxr-xr-x  3 chuck chuck 4096 Dec 18 02:36 .
drwxr-xr-x 13 chuck chuck 4096 Dec 18 02:54 ..
drwxr-xr-x  2 chuck chuck 4096 Dec 18 02:36 icr-15-linux-x86_64
chuck@papyplex:/var/lib/plexmediaserver/Plex Media Server/Drivers$ ll icr-15-linux-x86_64/
total 727716
drwxr-xr-x 2 chuck chuck      4096 Dec 18 02:36 ./
drwxr-xr-x 3 chuck chuck      4096 Dec 18 02:36 ../
lrwxrwxrwx 1 chuck chuck        13 Dec 18 02:36 libiga64.so -> libiga64.so.1
lrwxrwxrwx 1 chuck chuck        17 Dec 18 02:36 libiga64.so.1 -> libiga64.so.1.0.1
-rw-r--r-- 1 chuck chuck  16190456 Dec 18 02:36 libiga64.so.1.0.1
lrwxrwxrwx 1 chuck chuck        11 Dec 18 02:36 libigc.so -> libigc.so.1
lrwxrwxrwx 1 chuck chuck        15 Dec 18 02:36 libigc.so.1 -> libigc.so.1.0.1
-rw-r--r-- 1 chuck chuck 502610144 Dec 18 02:36 libigc.so.1.0.1
lrwxrwxrwx 1 chuck chuck        14 Dec 18 02:36 libigdfcl.so -> libigdfcl.so.1
lrwxrwxrwx 1 chuck chuck        18 Dec 18 02:36 libigdfcl.so.1 -> libigdfcl.so.1.0.1
-rw-r--r-- 1 chuck chuck  13014896 Dec 18 02:36 libigdfcl.so.1.0.1
-rwxr-xr-x 1 chuck chuck 129594152 Dec 18 02:36 libigdrcl.so*
-rwxr-xr-x 1 chuck chuck  11954608 Dec 18 02:36 libocloc.so*
-rw-r--r-- 1 chuck chuck  71783176 Dec 18 02:36 libopencl-clang.so.11
Remove the ‘Drivers’ directory (with PMS stopped).
When PMS restarts, it will pull the correct drivers (PMS 1.29.2) again.
icr-15-linux-x86_64
total 12
total 727716
NUC8i7hvk - in a VM - HD630 passthrough to the VM.
Now I sleep
so I’ve stopped PMS, deleted the Drivers folder, restarted PMS,
here’s the Drivers folder now :
While I was at it I’ve relaunch a 1080p video forced in 1080p@20m
Logs:
Plex Media Server Logs_2022-12-18_14-44-32.zip (324.1 KB)
This is a driver issue now.
trying to remember the magic. This is Ubuntu 22.04 being opportunistic and causing a conflct.
dpkg -l | grep gmmlib
Make certain you don’t have that installed
apparently no
2022-12-18 16-14-12
I will start asking around.
You are getting HW transcoding intermittently.
That tells me something isn’t letting go of the CPU correctly.
I’d love to tell you to go back to Ubuntu 20.04.5 LTS and run that LOLOL
just in case something stupid happened.
sudo update-initramfs -u
then restart the machine
:ok_hand:
:ok_hand:
then I’ve relaunch the LG video forced in 1080p@20m → NO BUFFERING, CPU under 15% the whole time
Logs:
Plex Media Server Logs_2022-12-18_16-02-52.zip (1001.3 KB)
That’s how it should be.
There is something silly happening there. Maybe we just fixed it. :crossed_fingers:
so still no 1.30.0 for the brave ?
tell me is everything seems fine on your side (logs), I’ll monitor everything during the week (the first and main issue was the server being unavailable), then I’ll make a feedback there
It all looks good to me.
PMS isn’t the issue here and hasn’t been.
I’m mostly at the limit of what I can do short of getting my hands in the machine and rebuilding it differently
1.29.2 gives you TrueHD audio working
If you don’t need that, 1.30.0 if you’re brave
I’ll monitor then, should we expect a fix for TrueHD in 1.30.2 or 1.31 ?
Thanks for all your help, analysis and time!
Probably 1.30.2 :crossed_fingers: but no promises
So after almost 1 week, no crash whatsoever. I can say my issue is now fixed, even if the “solution” is hidden in a lot of posts in this topic, I hope it might help people with a similar transcoding issue with LTS 22.
Again thanks for your help!
Logs (just in case) :
Plex Media Server Logs_2022-12-24_13-02-43.zip (5.8 MB)
