Since an upgrade, I guess it is since the dashboard changed, my server running on a Windows pc here at home can’t be reached by the app on my Sony TV. Ive upgraded the Plex server software but nothing Changed. Strange enough the server can be seen by the app on my android smartphone. What to do?
Are you referring to the app on your tv updating to the new experience?
How old is your Sony TV? Sony TVs running Android 7 can no longer connect with the new app. Folks have had to rollback to the old app.
And how can I rollback the app? The TV is 10 years old I think.
If you confirmed it’s Android 7, You’ll have to look for a guide on how to do it, don’t have a link to share. Can search for “sideload Sony tv”.
During the process you’ll need the old app apk, which is here: Release Announcements - Android TV beta - #729 by PlexAndroidReleaser
Suggest looking into a separate device as a long term solution.
Thx for the help. I’ve found the instructions for installing the old app apk. I’ll try that. In case I can’t fix it, then this will be a good reason to purchase a new TV ![]()
I’ll never stop someone from buying a new tv
, but if you’re happy with the picture quality, look into a standalone client, at least for the short term.
