Server pegs to 100% CPU and randomly stops running
I did the steps exactly as you stated and performed them again just to be sure.
Here is a screenshot of the CPU usage randomly jumping up to 12.5%. The first bump is from me clicking on “Download Database” from the troubleshoot menu. When I click it again; crash.
Enjoy your holiday, thanks for responding as much as you have.
Just heading out now.
  1. Stop Plex
  2. Make a tar.gz of the logs and attach here please when you can.
I’ll look when back
Logs.tar.gz (1.6 MB)
  1. Please identify device at 192.168.1.12 , disconnect it, take it out back, and shoot it ! :rofl:
    It’s spitting all over your LAN, and not obeying XML protocol. If you can turn off it advertising itself as a gateway, you’ll be much better off AND your logs will contain far less spam.
(Yes, I see it’s a player device … LOLOLOL)
Nov 24, 2022 11:04:57.941 [0x7f0fe3bfab38] ERROR - SSDP: Error parsing device schema for http://192.168.1.227:9080
Nov 24, 2022 11:04:58.000 [0x7f0fe3bfab38] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.1.12:9080
Nov 24, 2022 11:04:58.000 [0x7f0fe3bfab38] DEBUG - [HCl#50] HTTP requesting GET http://192.168.1.12:9080
Nov 24, 2022 11:04:58.005 [0x7f0fe7000b38] DEBUG - [HttpClient/HCl#50] HTTP/1.1 (0.0s) 200 response from GET http://192.168.1.12:9080
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - XML: Entity: line 1:\00
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - XML: parser\00
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - XML: error :\00
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - XML: Start tag expected, '<' not found\00
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - XML: status=ok\00
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - XML: ^\00
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - Error parsing content.
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - Error parsing XML: Error parsing file.
Nov 24, 2022 11:04:58.005 [0x7f0fe3bfab38] ERROR - SSDP: Error parsing device schema for http://192.168.1.12:9080
Nov 24, 2022 11:04:58.042 [0x7f0fe3bfab38] DEBUG - NetworkServiceBrowser: Parsing SSDP schema for http://192.168.1.96:9080
Nov 24, 2022 11:04:58.042 [0x7f0fe3bfab38] DEBUG - [HCl#51] HTTP requesting GET http://192.168.1.96:9080
Nov 24, 2022 11:04:58.046 [0x7f0fe7000b38] DEBUG - [HttpClient/HCl#51] HTTP/1.1 (0.0s) 200 response from GET http://192.168.1.96:9080
Nov 24, 2022 11:04:58.046 [0x7f0fe3bfab38] ERROR - XML: Entity: line 1:\00
Nov 24, 2022 11:04:58.046 [0x7f0fe3bfab38] ERROR - XML: parser\00
Nov 24, 2022 11:04:58.046 [0x7f0fe3bfab38] ERROR - XML: error :\00
Nov 24, 2022 11:04:58.046 [0x7f0fe3bfab38] ERROR - XML: Start tag expected, '<' not found\00
Nov 24, 2022 11:04:58.046 [0x7f0fe3bfab38] ERROR - XML: status=ok\00
Nov 24, 2022 11:04:58.046 [0x7f0fe3bfab38] ERROR - XML: ^\00
Nov 24, 2022 11:04:58.046 [0x7f0fe3bfab38] ERROR - Error parsing content.
  1. PMS is seeing an Nvidia GPU but – nothing is responding.
    – What do you have installed?
    – Does it have video transcode capability ?
    – Are Nvidia drivers installed? (I have 510.85 installed which is more than enough for AV1 decoding should you have a capable GPU card)
Nov 24, 2022 11:02:35.862 [0x7f0fe4f84b38] DEBUG - Codecs: testing h264_vaapi (encoder)
Nov 24, 2022 11:02:35.862 [0x7f0fe4f84b38] DEBUG - Codecs: hardware transcoding: testing API vaapi
Nov 24, 2022 11:02:35.863 [0x7f0fe4f84b38] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Nov 24, 2022 11:02:35.863 [0x7f0fe4f84b38] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: I/O error
Nov 24, 2022 11:02:35.863 [0x7f0fe4f84b38] DEBUG - Could not create hardware context for h264_vaapi
Nov 24, 2022 11:02:35.863 [0x7f0fe4f84b38] DEBUG - Codecs: testing h264_nvenc (encoder)
Nov 24, 2022 11:02:35.863 [0x7f0fe4f84b38] DEBUG - Codecs: hardware transcoding: testing API nvenc
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded lib: libcuda.so.1
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded sym: cuInit
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetCount
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetName
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded sym: cuCtxCreate_v2
Nov 24, 2022 11:02:35.864 [0x7f0fe4f84b38] DEBUG - [FFMPEG] - Loaded sym: cuCtxSetLimit
The .12 IP address is a FireStick (I have 4 of them on the network). I did some searching and couldn’t locate how to turn them off as a gateway so I’ll keep looking. I have an older 1080ti installed as the GPU and it does have transcoding capability from the table I found on the internet. I just changed the driver on the auto-updater and it looks like it’s using 515? However, I ran another log and I believe it’s still showing up.
The 1080ti should be fine. We use a GT-1050ti in our lab for all but AV1 testing.
Do you have the following modules installed ?
(Please understand , this is from my headless machine running Ubuntu server so Xorg isn’t used.)
You’re interested in the libnvidia modules for PMS and the nvidia-kernel for the the backend interface from card → OS.
[chuck@lizum Gemini Man (2019).2032]$ gog dpkg -l | grep nvidia | grep 510
ii  libnvidia-cfg1-510-server:amd64       510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-510-server           510.85.02-0ubuntu0.20.04.1        all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-510-server:amd64    510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA libcompute package
ii  libnvidia-decode-510-server:amd64     510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-510-server:amd64     510.85.02-0ubuntu0.20.04.1        amd64        NVENC Video Encoding runtime library
ii  libnvidia-extra-510-server:amd64      510.85.02-0ubuntu0.20.04.1        amd64        Extra libraries for the NVIDIA Server Driver
ii  libnvidia-fbc1-510-server:amd64       510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-510-server:amd64         510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  nvidia-compute-utils-510-server       510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA compute utilities
ii  nvidia-dkms-510-server                510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA DKMS package
ii  nvidia-driver-510-server              510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA Server Driver metapackage
ii  nvidia-kernel-common-510-server       510.85.02-0ubuntu0.20.04.1        amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-510-server       510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA kernel source package
ii  nvidia-utils-510-server               510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA Server Driver support binaries
ii  xserver-xorg-video-nvidia-510-server  510.85.02-0ubuntu0.20.04.1        amd64        NVIDIA binary Xorg driver
[chuck@lizum Gemini Man (2019).2033]$
This is what mine says.
First thing you’ll want to do is remove the ‘i386’ (32 bit) elements from the system unless you have other apps which need them. PMS is 64 bit only for HW transcoding.
You’re missing nvidia-compute-utils, nvidia-dkms, nvidia-driver (important)
Do you get output with
[chuck@lizum Gemini Man (2019).2033]$ nvidia-smi
Thu Nov 24 22:56:08 2022
| NVIDIA-SMI 510.85.02    Driver Version: 510.85.02    CUDA Version: 11.6     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Quadro P2200        On   | 00000000:07:00.0 Off |                  N/A |
| 47%   36C    P8     4W /  75W |      1MiB /  5120MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
[chuck@lizum Gemini Man (2019).2034]$
