There was no crash.
The server was commanded to shut down here:
(17 live) TLS GZIP 4ms 494 bytes (pipelined: 84)
Oct 17, 2022 08:29:40.625 [0x7f21da211b00] DEBUG - Shutting down with signal 15 (Terminated)
Oct 17, 2022 08:29:40.625 [0x7f21da211b00] DEBUG - Ordered to stop server.
Oct 17, 2022 08:29:40.625 [0x7f21de1c91c0] DEBUG - Stopping server...
Oct 17, 2022 08:29:40.625 [0x7f21de1c91c0] DEBUG - HttpServer: Stopping server.
Oct 17, 2022 08:29:40.625 [0x7f21d9ad0b00] DEBUG - MetadataItemClusterRequestHandler: a shutdown event has been received
Oct 17, 2022 08:29:40.625 [0x7f21d9ad0b00] DEBUG - TranscodeJobManager: [Running] onServerShutdown
Oct 17, 2022 08:29:40.625 [0x7f21d9ad0b00] DEBUG - TranscodeJobManager: [Running] -> [Shutdown]
Oct 17, 2022 08:29:40.625 [0x7f21de1c91c0] DEBUG - Server stopped.
Oct 17, 2022 08:29:40.625 [0x7f21de1c91c0] DEBUG - Killing job.
Oct 17, 2022 08:29:40.625 [0x7f21de1c91c0] DEBUG - Signalling job ID 5139 with 9
Oct 17, 2022 08:29:40.625 [0x7f21de1c91c0] DEBUG - Job was already killed, not killing again.
Oct 17, 2022 08:29:40.625 [0x7f21de1c91c0] DEBUG - Stopping transcode session 557c202c4403318b-com-plexapp-android
Oct 17, 2022 08:29:40.625 [0x7f21d2738b00] DEBUG - Cleaning directory for session 557c202c4403318b-com-plexapp-android (/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-557c202c4403318b-com-plexapp-android-532bc0ca-2a0a-4e31-a7e6-131367950dab)
Oct 17, 2022 08:29:40.626 [0x7f21de1c91c0] DEBUG - Transcoder: Cleaning old transcode directories.
Oct 17, 2022 08:29:40.626 [0x7f21de1c91c0] DEBUG - Transcoder: Cleaning old transcode directory: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-557c202c4403318b-com-plexapp-android-532bc0ca-2a0a-4e31-a7e6-131367950dab"
Oct 17, 2022 08:29:40.633 [0x7f21da211b00] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 5139 is -9 (signal: Killed)
Oct 17, 2022 08:29:40.634 [0x7f21de1c91c0] DEBUG - Whacked session 557c202c4403318b-com-plexapp-android, 0 remaining.
Oct 17, 2022 08:29:40.634 [0x7f21de1c91c0] DEBUG - Killing plug-ins.
Oct 17, 2022 08:29:40.646 [0x7f21de1c91c0] DEBUG - [com.plexapp.system] Killing.
Oct 17, 2022 08:29:40.648 [0x7f21da211b00] WARN - JobManager: Could not find job for handle 1398
Oct 17, 2022 08:29:40.649 [0x7f21de1c91c0] DEBUG - ChildProcessMonitor: Waiting for Plex Tuner Service to exit.
Oct 17, 2022 08:29:40.649 [0x7f21de1c91c0] DEBUG - [JobRunner] Signalling job ID 1463 with 2
Oct 17, 2022 08:29:40.708 [0x7f21da211b00] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Tuner Service' exit code for process 1463 is 0 (success)
Oct 17, 2022 08:29:40.708 [0x7f21d34b9b00] DEBUG - [ChildProcessMonitor] Plex Tuner Service exited.
Oct 17, 2022 08:29:40.709 [0x7f21de1c91c0] DEBUG - Database: Shutting down.
Oct 17, 2022 08:29:40.730 [0x7f21de1c91c0] DEBUG - Database: Shutting down.
and also here.
(19 live) TLS GZIP 2ms 454 bytes (pipelined: 1092)
Oct 17, 2022 04:45:01.391 [0x7fe2374f3b00] DEBUG - Shutting down with signal 15 (Terminated)
Oct 17, 2022 04:45:01.391 [0x7fe2374f3b00] DEBUG - Ordered to stop server.
Oct 17, 2022 04:45:01.391 [0x7fe23b4ab1c0] DEBUG - Stopping server...
Oct 17, 2022 04:45:01.391 [0x7fe23b4ab1c0] DEBUG - HttpServer: Stopping server.
Oct 17, 2022 04:45:01.391 [0x7fe236db2b00] DEBUG - MetadataItemClusterRequestHandler: a shutdown event has been received
Oct 17, 2022 04:45:01.391 [0x7fe236db2b00] DEBUG - TranscodeJobManager: [Running] onServerShutdown
Oct 17, 2022 04:45:01.391 [0x7fe236db2b00] DEBUG - TranscodeJobManager: [Running] -> [Shutdown]
Oct 17, 2022 04:45:01.391 [0x7fe23b4ab1c0] DEBUG - Server stopped.
Oct 17, 2022 04:45:01.391 [0x7fe23b4ab1c0] DEBUG - Killing job.
Oct 17, 2022 04:45:01.391 [0x7fe23b4ab1c0] DEBUG - Signalling job ID 10983 with 9
Oct 17, 2022 04:45:01.391 [0x7fe23b4ab1c0] DEBUG - Job was already killed, not killing again.
Oct 17, 2022 04:45:01.391 [0x7fe23b4ab1c0] DEBUG - Stopping transcode session e8uyhcld3pd4ign0lxdcw49m
Oct 17, 2022 04:45:01.392 [0x7fe22eaceb00] DEBUG - Cleaning directory for session e8uyhcld3pd4ign0lxdcw49m (/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-e8uyhcld3pd4ign0lxdcw49m-f6472e33-e893-4338-9bc0-76df84a4b7e0)
Oct 17, 2022 04:45:01.393 [0x7fe23b4ab1c0] DEBUG - Transcoder: Cleaning old transcode directories.
Oct 17, 2022 04:45:01.394 [0x7fe23b4ab1c0] DEBUG - Transcoder: Cleaning old transcode directory: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-e8uyhcld3pd4ign0lxdcw49m-f6472e33-e893-4338-9bc0-76df84a4b7e0"
Oct 17, 2022 04:45:01.396 [0x7fe23b4ab1c0] DEBUG - Whacked session e8uyhcld3pd4ign0lxdcw49m, 0 remaining.
Oct 17, 2022 04:45:01.396 [0x7fe23b4ab1c0] DEBUG - Killing plug-ins.
Oct 17, 2022 04:45:01.413 [0x7fe23b4ab1c0] DEBUG - [com.plexapp.system] Killing.
Oct 17, 2022 04:45:01.415 [0x7fe2374f3b00] WARN - JobManager: Could not find job for handle 1402
Oct 17, 2022 04:45:01.416 [0x7fe23b4ab1c0] DEBUG - ChildProcessMonitor: Waiting for Plex Tuner Service to exit.
Oct 17, 2022 04:45:01.416 [0x7fe23b4ab1c0] DEBUG - [JobRunner] Signalling job ID 1470 with 2
Oct 17, 2022 04:45:01.464 [0x7fe2374f3b00] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Tuner Service' exit code for process 1470 is 0 (success)
Oct 17, 2022 04:45:01.464 [0x7fe23066ab00] DEBUG - [ChildProcessMonitor] Plex Tuner Service exited.
Oct 17, 2022 04:45:01.466 [0x7fe23b4ab1c0] INFO - Killing process: Plex EAE Service (pid: 1515)
Oct 17, 2022 04:45:01.466 [0x7fe23b4ab1c0] DEBUG - Killing job.
Oct 17, 2022 04:45:01.466 [0x7fe23b4ab1c0] DEBUG - Signalling job ID 1515 with 9
Oct 17, 2022 04:45:01.474 [0x7fe23b4ab1c0] DEBUG - Database: Shutting down.
Oct 17, 2022 04:45:01.486 [0x7fe2374f3b00] DEBUG - Jobs: '/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-1785-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder' exit code for process 1515 is -9 (signal: Killed)
Oct 17, 2022 04:45:01.495 [0x7fe23b4ab1c0] DEBUG - Database: Shutting down.
Do these correlate to anything?
