Server Randomly Shutting Down
I do…my etc/fsab is:
lance@PLEX-Server:~$ more /etc/fstab
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/boot/efi was on /dev/sda1 during installation
UUID=873B-15FD /boot/efi vfat umask=0022,fmask=0022,dmask=0022 0 1
/boot/efi/grub /boot/grub none defaults,bind 0 0
UUID=f493dad4-151a-43e6-81d2-78fd25b80ec8 none swap sw 0 0
192.168.1.247:/volume1/data /mnt nfs
Is there a better way? My son was my Unix guru before he passed, not I just try to use what I remember
I changed my /etc.fstab , adding
defaults,sec=sys,rw,auto,async,rsize=4194304,wsize=4194304,x-systemd.after=network-online.target,nofail,bg 0 0
to my mount
so now it’s like yours
192.168.1.247:/volume1/data /mnt nfs defaults,sec=sys,rw,auto,async,rsize=4194304,wsize=4194304,x-systemd.after=network-online.target,nofail,bg 0 0
Back to Christmas movies…if this works, I owe you a bottle of Bourbon sir!
Things to watch for .
  1. sec=sys changed authentication to UID/GID mode.
    Normally it’s username=username mode.
    If Plex can’t access media, this is likely candidate,
  2. If you want Read-Only for your media, switch rwro
Thank you, I made the change, restarted, and it’s running. So, now I watch what the wife picked out and wait to see. Thank you for your help, Merry Christmas!! I’ll let you know what comes of the changes
Merry Christmas to you and all as well!
Well…THOUGHT I had it fixed, but it’s still occurring, so far I have:
Synology Side (NFS Server) Checks
-Enabled NFS: (obviously it is because it’s been working for years)
-Checked NFS Permissions:
-Ubuntu client IP is in there.
-Privileged Access to Read/Write
-Under Squash, I changed to “map all users to admin”
-Restarted NFS
-Checked firewall:
-Synology firewall disabled
Client Side:
-Ensured NFS-common is up to date
-Checked /etc/fstab line for typos: looks to be good:
So, then I looked at all the logs, client kept giving me the following:
nfs: server 192.168.1.247 not responding, still trying
I then looked at the server and saw many of the following errors, all beginning in July:
sudo cat /var/log/messages | grep 192.168.1.97
MAYFIELD kernel: [2697535.436064] NFSD: client 192.168.1.97 testing state ID with incorrect client ID
A quick google search revealed an outdated kernel…and I discovered my Synology NES was pretty far out of date.
I updated it to the most recent version of DSM and thought it fixed it but after watching movies for about 3 hours it happened again
