Server Version#:1.42.2.10156
Player Version#:4.147.1
My server, while watching, will randomly stop playing. I’m running Ubuntu 24.04.3 LTS.
I can ssh into the server, services are up, memory is good. But when this happens I can’t access Plex via web browser. It happens often, but I can’t for the life of me figure out why. Not sure what logs are needed. Attaching the log that was during the time of it freezing most recently.
I think I’ll run your db repair utility because in looking at the logs I see it trying to hit my old xSteve server which I haven’t had in at least a year. In looking at the PMS settings I don’t even have the tuner setup in there.
This stopping of playing is very frustrating as I cannot pin down the cause. It’s so random
I ran your DB repair, I’ll see if that fixes anything:
Automatic Check,Repair,Index started.
Checking the PMS databases
Check complete. PMS main database is OK.
Check complete. PMS blobs database is OK.
Exporting current databases using timestamp: 2025-12-21_22.02.30
Exporting Main DB
Exporting Blobs DB
Successfully exported the main and blobs databases.
Start importing into new databases.
Importing Main DB.
Importing Blobs DB.
Successfully imported databases.
Verifying databases integrity after importing.
Verification complete. PMS main database is OK.
Verification complete. PMS blobs database is OK.
Saving current databases with ‘-BACKUP-2025-12-21_22.02.30’
Making repaired databases active
Repair complete. Please check your library settings and contents for completeness.
Recommend: Scan Files and Refresh all metadata for each library section.
Backing up of databases
Backup current databases with ‘-BACKUP-2025-12-21_22.04.32’ timestamp.
Reindexing main database
Reindexing main database successful.
Reindexing blobs database
Reindexing blobs database successful.
Reindex complete.
Automatic Check, Repair/optimize, & Index successful.
No, still not reachable. I discovered that my PiHole was not allowing local access so I resolved that.
It just shut down again and I’m think it has something to do with the mount to my NAS. I ran a dmesg and it looks like there’s issues with the NAS but I can access it from every other platform.
