Server Stops Running Frequently
The past few weeks, my Plex server has stopped running a few times a week. I have to log into the DiskStation and manually Run Plex to get it to run again. I am running the server on a DS916+. I was unable to capture the crash logs this time, but attached the regular server logs. I thought it seemed to correspond to when I upgraded to 1.15.3.876, but just checked and the first time I noticed it, was before then (probably on 1.15.2). I also noticed a couple times I logged into the DiskStation, it was giving me a high temperature warning, which I also never saw prior to this.
Plex Media Server Logs_2019-04-21_18-45-29.zip (2.5 MB)
Server Version#: 1.15.3.876
Thanks! I had no idea about the plex pass versions. Strange, I have had those files since November, but it only started causing issues in the past month. Looks like those are found in the Scanner and Deep Analysis Logs. Seem to be a few episodes from that specific season throwing exceptions. I’ll remove the season and monitor.
