Server unavailable after updating to version 1.40.3
Login to the NAS via SSH and navigate to the directory holding the database files.
Enter ls -la and copy the output to the thread.
Enter ls -la .. and copy the output to the thread.
It will show file ownership, permissions, etc. of the directory and files (like example earlier in thread from my Synology NAS). Can then determine if anything needs to be modified.
[Myrddid@TNAS-107B Databases]# ls -la
total 1417168
drwxrwx---+ 1 plex    media        1238 Jun 24 18:39  .
drwxrwx---+ 1 plex    media         100 May 21  2023  ..
-rwxrwx---+ 1 Myrddid Myrddid         0 Jun 29 20:15  com.plexapp.plugins.librar        y.blobs.db
-rwxrwx---+ 1 Myrddid Myrddid 212743168 May  2  2023  com.plexapp.plugins.librar        y.blobs.db-2023-05-02
-rwxrwx---+ 1 Myrddid Myrddid 212973568 May  5  2023  com.plexapp.plugins.librar        y.blobs.db-2023-05-05
-rwxrwx---+ 1 Myrddid Myrddid 213517312 May  8  2023  com.plexapp.plugins.librar        y.blobs.db-2023-05-08
-rwxrwx---+ 1 plex    media      342016 May 23  2023  com.plexapp.plugins.librar        y.blobs.db-2023-05-23
-rwxrwx---+ 1 plex    media   220045312 Jun  7  2023  com.plexapp.plugins.librar        y.blobs.db-2023-06-07
-rwxrwx---+ 1 plex    media     1736704 Jun 27 14:16  com.plexapp.plugins.librar        y.blobs.db-shm
-rwxrwx---+ 1 plex    media   224594816 Jun 27 14:16  com.plexapp.plugins.librar        y.blobs.db-wal
-rw-rwx---+ 1 plex    media    56741888 Jun 29 20:15  com.plexapp.plugins.librar        y.db
-rw-rwx---+ 1 plex    media    61585408 Jun 24 18:38  com.plexapp.plugins.librar        y.db-2024-03
-rw-rwx---+ 1 plex    media    61044736 Apr 20 02:00  com.plexapp.plugins.librar        y.db-2024-04-20
-rw-rwx---+ 1 plex    media    61585408 Jun 10 02:02  com.plexapp.plugins.librar        y.db-2024-06-10
-rwxrwx---+ 1 Myrddid Myrddid  61585408 Jun 17 08:42  com.plexapp.plugins.librar        y.db.bak
-rw-rwx---+ 1 plex    media       32768 Jun 27 14:15  com.plexapp.plugins.librar        y.db-shm
-rw-rwx---+ 1 plex    media    62628512 Jun 24 18:40  com.plexapp.plugins.librar        y.db-wal
drwxrwx---+ 1 Myrddid Myrddid        82 May 21  2023 'Music Analysis 3'
Mod Edit: formatting. @FordGuy61
[Myrddid@TNAS-107B Databases]# ls -la …
total 0
drwxrwx—+ 1 plex media 100 May 21 2023 .
drwxrwx—+ 1 plex media 286 Jun 27 14:16 …
drwxrwx—+ 1 plex media 1122 May 21 2023 Caches
drwxrwx—+ 1 plex media 1122 May 21 2023 Data
drwxrwx—+ 1 plex media 1238 Jun 24 18:39 Databases
drwxrwx—+ 1 plex media 406 May 21 2023 ‘Metadata Combination’
drwxrwx—+ 1 plex media 550 May 21 2023 Preferences
The owner of db files seems to be incorrect…
Thanks for the output of the commands.
Yep. owner:group should be plex:media.
So here’s the deal. If root existed this would be easy. It doesn’t, and I don’t know which userid has enough privileges to execute the chown (change owner) command.
Try some variations.
Change to the directory holding the files, then try these variations:
Using your userid (I don’t expect this to work):
chown plex:media com.plexapp.
chown -R plex:media "Music Analysis 3"
This normally invokes the root account:
sudo chown plex:media com.plexapp.
sudo chown -R plex:media "Music Analysis 3"
Also, try as user plex:
sudo -u plex chown plex:media com.plexapp.
sudo -u plex chown -R plex:media "Music Analysis 3"
See if either of those work. I’ll see if I can find more info as well.
It worked using my my userid:
total 1417168
-rwxrwx---+ 1 plex media         0 Jun 29 20:15  com.plexapp.plugins.library.blobs.db
-rwxrwx---+ 1 plex media 212743168 May  2  2023  com.plexapp.plugins.library.blobs.db-2023-05-02
-rwxrwx---+ 1 plex media 212973568 May  5  2023  com.plexapp.plugins.library.blobs.db-2023-05-05
-rwxrwx---+ 1 plex media 213517312 May  8  2023  com.plexapp.plugins.library.blobs.db-2023-05-08
-rwxrwx---+ 1 plex media    342016 May 23  2023  com.plexapp.plugins.library.blobs.db-2023-05-23
-rwxrwx---+ 1 plex media 220045312 Jun  7  2023  com.plexapp.plugins.library.blobs.db-2023-06-07
-rwxrwx---+ 1 plex media   1736704 Jun 27 14:16  com.plexapp.plugins.library.blobs.db-shm
-rwxrwx---+ 1 plex media 224594816 Jun 27 14:16  com.plexapp.plugins.library.blobs.db-wal
-rw-rwx---+ 1 plex media  56741888 Jun 29 20:15  com.plexapp.plugins.library.db
-rw-rwx---+ 1 plex media  61585408 Jun 24 18:38  com.plexapp.plugins.library.db-2024-03
-rw-rwx---+ 1 plex media  61044736 Apr 20 02:00  com.plexapp.plugins.library.db-2024-04-20
-rw-rwx---+ 1 plex media  61585408 Jun 10 02:02  com.plexapp.plugins.library.db-2024-06-10
-rwxrwx---+ 1 plex media  61585408 Jun 17 08:42  com.plexapp.plugins.library.db.bak
-rw-rwx---+ 1 plex media     32768 Jun 27 14:15  com.plexapp.plugins.library.db-shm
-rw-rwx---+ 1 plex media  62628512 Jun 24 18:40  com.plexapp.plugins.library.db-wal
drwxrwx---+ 1 plex media        82 May 21  2023 'Music Analysis 3'
May I try now to activate PMS?
Absolutely.
Too bad, it fails enabling, it doesn’t even open…
I’m going to try to repair a db backup by Plex which at least should not fail enabling… it has 3 months, but it’s better than nothing.
I see that your permissions differ from mine…
-rw-r–r–
Is it important?
No way, I didn’t see that after repair the file *blobs.db was 0B, I’m afraid I must start from scrtach.
Thank you very much for your precious help, I should have been more… careful about all this thing. I will manage backups better, I promise.
Well, the problem seems to be in the repair process: it generates an empty bloob.db file with 0B… what could be wrong?
Plus, Windows Power Shell tells me that:
NOTE: This script is being replaced with the PowerShell script DBRepair-Windows.ps1,
which aims to better emulate DBRepair.sh (more options, interative mode, etc).
Consider moving over to the new script.
New update: I can run sudo command on TNAS, I simply added root user and it works.
Now I’m going to try ssh commands to repair db.
Repair done, PMS starts but doesn’t open.
What if I reinstalled it and copied the 2 .db files on new installation?
Well, I deleted Plex and start over, it’s been a mess but now it works, thanks to @FordGuy61 for precious help.
Now I’ve got an issue: I can’t see plots in TV Shows section… Tried to work with agents but no changes… Any suggention?
RIP my notifications. I never got any badges and missed that EPIC help from @FordGuy61
Look at that thread. Incredible.
So glad you got it working in the end and learned a lot.
As far as that goes, two things: First, the Plex website Articles are the user’s manual in dispersed form. I refer to them a lot for everything from naming my files to media Agents. Secondly to give you a foundation, nowadays nearly everybody uses the modern, default:
Scanner: Plex TV Series
Agent: Plex Series
Episode Ordering: The Movie Database
Once you have those changed, and “Saved” you would Manage Library →
  1. Scan Library Files
  2. Refresh All Metadata
That refresh takes a while depending on your internet speed and library size. For 1000 shows it might be 10 - 30min. Occasionally a show will have terribly incomplete or missing episode data which you will often have to look at manually to see if it exists on the TMDB website. When it’s missing you then check the TVDB website which is more complete. For a show that needs to use TVDB, I Edit the show’s link → Advanced to use
Episode Ordering: TheTVDB (Aired)
Sometimes I have to rename my media files to match whichever ordering I’ve chosen, because one site might break up, for example, Doctor Who in three series, while the other clumps everything into one show.
HTH nib
Well, I learned very much indeed and yes, help from @FordGuy61 has been really EPIC!!!
Now, about series plot issue… It solved, it seemed to take over 2 days to complete libraries scanning, but in the end, plots appeared…
Thanks for your suggestion about managing agents and naming files: file names were already set up, because I’ve already done this thing years ago; I’ve found very useful the advice about how manage agents, because I think it’s a bit complicated to understand the difference between TVDB and MovieDataBase…
Thank you again
