Hello.
Sorry if this has been addressed before, I did read up and saw a handful of similar issues but none really gave a clear answer…
I upgraded my FreeNAS 9.3 to 9.10 yesterday and the Plex plugin I had running stopped working - something I read was pretty common. As a plexpass subscriber, I would like to get that up and running in a jail anyways. I got the jail started, did a pkg search for plex and I installed plexmediaserver-plexpass-0.9.16.6.1993 and all seems well. The problem is that the service is not running in the jail, when i run: top then I only see 4 services running (csh, top, cron syslogd). I try to start the service manually with: service plexmediaserver_plexpass start and it says that it is starting the service but there are no changes when I run top again. running service plexmediaserver start fails saying it does not exist in /etc/rc/d or the local startup, as expected. I recall seeing an install command that requires your username and password a couple months ago when I was messing around with this but never came across that this time around, maybe that is the missing link?
Can anyone point me in the right direction or let me know what other info you need from me?
Thanks!
sorry for the same post in the plex pass thread… i was not sure how to delete / move it so i reposted here
You havn’t simply forgotten to add it to /etc/rc.conf?
If it’s not in /etc/rc.conf you have to use service plexmediaserver_plexpass onestart.
I was having this exact same issue and atti’s solution worked for me. Thank you.
