Set subtitles for shows/seasons from clients
I’m agree with halono.
The global setting isn’t enough.
For some mangas i prefer watch in japanese with french subtitles.
In some series in english with french subtiltes
But some other juste in french with no subtitles.
It can’t be juste one parameter for all the library.
You should be able to configure at least for one entier Season or serie.
(When you have 50 episodes to change 1 by 1 it’s too long…
As pointed out above, you can already do that:
  • for shows
  • for seasons
  • for individual episodes
Yes but on the server only, and for all users I guess.
But the problem is that it’s not possible on Plex Client (HTPC and Android)
Or I don’t found the way to do that …
And for me it’s annoying to have to connect to the server to do this instead of the client.
No and no.
But yes, you will have to use the Plex web app or Plex for Desktop.
Ok so no on versions that i already use ^^’
That’s why I think it was not possible so…
Thanks anyway
