Hey guys,
Would love to be able to set default setting for language/audio track and subtitle and apply seperate settings to different series/shows
Both is already possible.
https://support.plex.tv/articles/204985278-account-audio-subtitle-language-settings/
Sorry I could not find that option through the android app! I will do from the web - cheers
I checked your info, this is for system wide settings. I am hoping to apply it to single series or shows
Go to the show
make sure you are at the top level (i.e. NOT at the season or episode level) – easiest to do by clicking on the show’s title.
Edit the show
Go to the Advanced tab, scroll all the way down.
Thankyou !
