Is there any way to setup Live TV with no guide? If I select Australia there is only an option to use XMLTV and the Continue button is disabled.
The only way I have found to get Live TV is to select another country and proceed that way. I don’t want to set up XMLTV.
No there isn’t another way.
Why would you not want to setup xmltv?..
In the interests of simplicity. Setting up xmltv requires extra work and if I am not interested in the recording (DVR) side side it shouldn’t be required just to watch TV.
You need to set up a guide, that’s the way it is. You can use Ice TV, $3.99 per month https://www.icetv.com.au/plex-subscription/ or a free xmltv http://www.xmltv.net/
Okay, so I found a URL I could put in the XMLTV setup. So in the end it was easy.
I found xmltv.net after a little googling. Pity it isn’t the default value in the setup.
I would suggest you use xmltv.net
Really useful service and has basically all channels
markcs
April 29, 2020, 4:13am
8
If any channels are missing, post on xmltv.net page with the region you are in and which channels are missing and we’ll see if we can fix that …
