Setup Live DVR
When trying to setup the Live TV/ DVR I can get to the point where I select the lauange and normally the post code but the post code option does not show up as an option to select
Server Version#: Synology 1.18.9.2571-e106a8a91
Tuner Make/Model: Silicondust HDHomeRun CONNECT
What country are you selecting during setup? Is it one of the ones listed here?
If not, you’ll need to source XMLTV guide data.
Thank you,
I am in Australia and as such not linsted.
No problem.
You can still use Live TV & DVR with Plex if you supply your own XMLTV guide data. Do a Google search for “Australia XMLTV” and you should get a few good options, some of them free. In particular, I think xmltv.net was created by some folks on these forums; and IceTV had a special for Plex users at one point.
