Hello
I’m running the Plex media server on my Raspberry Pi 3.
I’ve created a new media library on my Airport Time Capsule.
I would like to use this library as my main media location.
How can I had this library to the Plex media server? when I’m going to “add library” I don’t see my NAS there.
Doesn’t the Airport use SMB protocol?
Did you mount your shares and give user plex permission to read them in that mount?
yes - it uses SMB protocol
didn’t mount the drive … :#
can you explain to me how to mount the drive and give plex permission to read from it?
thanks
As I pointed out above, please see the Linux Tips section at the top of this forum https://forums.plex.tv/categories/linux-tips where I expressly show how to mount your network shares.
Thanks - I have tried to look at this forums and other forums but still nothing.
Let me please explain what exactly I did and to where I got till now:
- My Airport Time Machine is connected to my network in the regular way. I can see the time capsule in my MacBook pro and it contains 1 folder called “Data” , inside there’s my 1 file backup and another folder where I store all my media files:
I found in some raspberry Pi forums the things I need to run in the RP3 Terminal:
sudo su
mkdir /mnt/timecapsule
echo “//192.168.1.21/Date /mnt/timecapsule cifs user=My User Name,pass= Password,rw,uid=1000,iocharset=utf8,sec=ntlm 0 0” >> /etc/fstab
now , when i go to the plex server page to add media I see this structure:
I think that the folder I see called “timecapsule” it’s the one I have created in the command “mkdir /mnt/timecapsule” and not the actual HDD I have in my time capsule.
I hope that with this long post with the photos I can finish this installation process
please help if you can
I’m new to all the RP3 stuff
thanks in advance
It looks like you’re having permission problems. User plex must have permission to read . It doesn’t look like your mount options in /etc/fstab accounted for this. You’re using your username, and not specifying a group (which is one way to let group plex) have access. I am suggesting your username have read/write but group plex have read permission through group permissions
