Shared Libraries in Endless Loop
Hi all,
I have successfully connected Plexconnect to my apple tv (without any user id). However, I am unable to configure a specific plex id to work as I limit the plex libary that my kids can access.
I can see from the logs that the user successfully signs into plexconnect
12:39:09 PlexAPI: MyPlex Sign In successfull
However, whenever I try to to access shared libraries, accessing trailers keeps spinning endlessly.
Logs are below
12:38:38 DNSServer: Domain: trailers.apple.com
12:38:38 DNSServer: ***intercept request
12:38:38 DNSServer: -> DNS response: 192.168.100.200
12:38:38 WebServer: serving .xml: /
12:38:38 PlexAPI: ***
12:38:38 PlexAPI: looking up Plex Media Server
12:38:39 PlexAPI: GDM: Servers discovered: 1
12:38:39 PlexAPI: Servers (local+MyPlex): 1
12:38:40 WebServer: serving .xml: /
12:39:06 WebServer: serving .xml: /
12:39:09 WebServer: serving .xml: /
12:39:09 PlexAPI: ***
12:39:09 PlexAPI: looking up Plex Media Server
12:39:10 PlexAPI: GDM: Servers discovered: 1
12:39:12 PlexAPI: Servers (local+MyPlex): 1
12:39:12 WebServer: serving .xml: /
12:39:12 WebServer: serving .xml: /PlexConnect.xml
12:39:13 WebServer: serving .xml: /
12:39:13 WebServer: serving /js/utils.js
12:39:14 WebServer: serving .xml: /library/sections
12:39:15 WebServer: serving /js/utils.js
12:39:16 WebServer: serving /js/sectionHoldSelect.js
12:39:19 WebServer: serving .xml: /library/sections
12:39:19 WebServer: serving /js/utils.js
12:39:20 WebServer: serving /js/sectionHoldSelect.js
12:39:20 WebServer: serving /js/utils.js
12:39:20 WebServer: serving /js/settings.js
12:39:21 WebServer: serving .xml: /
12:39:21 WebServer: serving .xml: /library/sections
12:39:22 WebServer: serving /js/utils.js
12:39:22 WebServer: serving /js/sectionHoldSelect.js
12:42:29 DNSServer: DNS request received!
12:42:29 DNSServer: Source: ('162.212.181.242', 13648)
12:42:29 DNSServer: Domain: wwww.jrdga.info
12:42:29 DNSServer: ***forward request
12:42:29 DNSServer: -> DNS response from higher level
loglevel=High + attach the log file. It then will contain the generated XMLs as well, and we might be able to figure out what's wrong.
