Shared Libraries not showing up
Hi everyone!
I have PlexConnect set up so that my family could view my libraries via our Apple TV. As I didn't want them to affect my On Deck and played/unplayed I created a dummy Plex account and shared my Movie and TV libraries with it. I then signed into PlexConnect using this account and those libraries would show up in the Shared Libraries section. This has worked for me for quite a while and it meant that they could watch what they wanted via Shared Libraries on PlexConnect and have their own On Deck separate from my own. A couple of days ago Shared Libraries all of a sudden stopped showing up (No Plex Library Sections Available is displayed) and the only way I could access my libraries was by disabling authentication and having them show up in the local libraries section. This defeats the purpose of me creating the separate account in the first place as anything they watch now affects my On Deck.
  • ATV3 firmware version 6.2 (6698.99.50.31)
  • DNS server: 192.168.0.30
  • PlexConnect local IP: 192.168.0.30
  • PlexConnect OS: Main Desktop, Windows 8.1 Pro 64-bit
  • PMS OS: Main Desktop, Windows 8.1 Pro 64-bit
  • PMS version number: 0.9.11.7.803-87d0708
  • PMS local IP: 192.168.0.30
  •  PlexConnect version number: Github, ‎22 ‎January ‎2015, ‏‎20:52:35
  • [PlexConnect]
    enable_plexgdm = True
    ip_pms = 192.168.000.30
    port_pms = 32400
    enable_dnsserver = True
    port_dnsserver = 53
    ip_dnsmaster = 8.8.8.8
    prevent_atv_update = True
    enable_plexconnect_autodetect = True
    ip_plexconnect = 0.0.0.0
    hosttointercept = trailers.apple.com
    port_webserver = 80
    enable_webserver_ssl = True
    port_ssl = 443
    certfile = ./assets/certificates/trailers.pem
    allow_gzip_atv = False
    allow_gzip_pmslocal = False
    allow_gzip_pmsremote = True
    loglevel = High
    logpath = .
  • http://pastebin.com/VJYFZBQm
Thanks to anyone that can help!
a. aTV still logged into myPlex? Sign out/in again?
b. There is a setting to hide top items: aTV->PlexConnect->Settings->Main Nav Bar->...
Hi, thanks for the reply. I tried signing in and out of myPlex on aTV but it didn't seem to work. The Shared Library section is enabled on the Main Nav Bar, it shows "No Plex Library Sections Available".
And from discovery:
12:38:05 PlexAPI:
I guess you have no one sharing a library, do you?
I'm not sure what you mean. When I log into the same account via the Web App the shared libraries show up like normal. These libraries have been shared from my main Plex account and have been showing up fine in PlexConnect for months until they disappeared a few days ago. Hope that answers your question!
Maybe this is an issue of PlexConnect (until today) not supporting the Plex Home feature? Try the new version and see if it works now?
