I usually filter movies as Unwatched, but recently this now includes all watched collections. There is no option on the shield player to select movies or collections from the Movies drop down (the one between the filter and the sort option), but this is available on other players and also TV shows on the shield.
Will there be an option added to the Shield for Movies so you can select Movies or Collections or is there a work around to remove collections when filtering on Unwatched? I have disabled collections in the Library advanced settings but that doesn’t seem to make any difference.
