Anyone else having issues with searching for shows on.live tv program guide?
I am using the plex app on the nvidia shield tv (2017). It crashes when I voice search or even type search for a show.
I have the same issue, or close to it. When i use the voice search in the plex app/live tv on shield tv (2017) preview release 5.2 it crashes when i click on search results. The search itself works.
ditto. I can type in about 2 letters in the search bar before it actually starts executing the search, and crashes. in case it might be relevant, I’m using a cable input with ~240 channels, curious if other users seeing this have a similar setup
The next build will have a crash fix for this.
And alas, it did fix it. Thanks!
I experienced this right after the release of liv tv. I was able to get it to work fine by simply clearing the data for the Plex app and then reconnecting it.
