Hello
I hole this is the proper way to create this post!=)
I just purchased this device, set it up and all seems to work, but when i want to playback demo files, the plex app crashes, rendering me back to the home screen of PLEX, some clips do this in the wery start, other later in the clip.
Shield TV Pro 16GB, model number: P2897 V.9
Shield Android TV Version: 8.1.1(32.7.301.99)
Player Version#:8.4.2.19372
Date: 2020-08-02 14:39:23
Build: NVIDIA/mdarcy/mdarcy:9/PPR1.180610.011/4199437_1915.8582:user/release-keys
Serial number: 1322320002863
08-01 23:29:18.192 9582 9582 E AndroidRuntime: FATAL EXCEPTION: main
08-01 23:29:18.192 9582 9582 E AndroidRuntime: Process: com.plexapp.android, PID: 9582
08-01 23:29:18.192 9582 9582 E AndroidRuntime: java.lang.NullPointerException: Attempt to invoke interface method ‘android.view.View com.plexapp.plex.adapters.s0.h$a.a(android.view.ViewGroup)’ on a null object reference
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at com.plexapp.plex.home.p0.d.onCreateViewHolder(SourceFile:3)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at com.plexapp.plex.home.p0.d.onCreateViewHolder(SourceFile:1)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$Adapter.createViewHolder(SourceFile:2)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$Recycler.tryGetViewHolderForPositionByDeadline(SourceFile:34)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$Recycler.getViewForPosition(SourceFile:2)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$Recycler.getViewForPosition(SourceFile:1)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.leanback.widget.GridLayoutManager.getViewForPosition(SourceFile:1)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.leanback.widget.GridLayoutManager$2.createItem(SourceFile:1)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.leanback.widget.SingleRow.appendVisibleItems(SourceFile:4)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.leanback.widget.Grid.appendOneColumnVisibleItems(SourceFile:1)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.leanback.widget.GridLayoutManager.appendOneColumnVisibleItems(SourceFile:1)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.leanback.widget.GridLayoutManager.onLayoutChildren(SourceFile:63)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView.dispatchLayoutStep2(SourceFile:8)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView.dispatchLayout(SourceFile:9)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView.consumePendingUpdateOperations(SourceFile:18)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at androidx.recyclerview.widget.RecyclerView$1.run(SourceFile:6)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.view.Choreographer$CallbackRecord.run(Choreographer.java:949)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.view.Choreographer.doCallbacks(Choreographer.java:761)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.view.Choreographer.doFrame(Choreographer.java:693)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:935)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.os.Handler.handleCallback(Handler.java:873)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:99)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.os.Looper.loop(Looper.java:193)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6720)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
08-01 23:29:18.192 9582 9582 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
Best regards
