Show episode synopsis
Hi guys,
I am sure this is fairly simple however I can’t figure it out. My episode synopsis are not showing for unwatched shows. I googled the issue and found this page :
https://github.com/iBaa/PlexConnect/issues/158
It says to select aTV->PlexConnect->TV Show Options->Unwatched Synopsis however it doesn’t say where to do this. I tried double clicking on ATVsettings in the plex connect folder but a cmd window just pops up and disappears. Could someone point this noob in the right direction?
On the Apple TV itself: Plex (i.e. "Trailers", or whatever you're hijacking) > Settings > TV Show Options > Unwatched Synopsis
Thank you so much. I didn’t realise there was a Settings menu on the appletv itself. It was a bit hard to find but I got it. Feel rather silly now lol so simple! Thanks again.
No problem! Part of the joy of mucking with your ATV is feeling silly and/or dumb at least once a month. :)
As a related comment, I find that I make the referenced change, and the synopsis is available. Then a few days later... they are gone, and the setting needs to be re-applied. Any thoughts on why its not sticking? Its a bit frustrating - for others in the house...!
Make sure you're killing the PlexConnect process "gently" by typing Control-C while looking at it in the Terminal (or the Windows equivalent). If you reboot your computer (for example) and let it kill the process on its own, none of your settings will be saved to disk.
