Show IMDB as well as Rotten Tomatoes
Hi all, I’m curious if it’s possible to obtain multiple ratings and display them on movies. I love to have both the IMDB rating as well as RT critic and RT audience! I can’t figure out a way to do it though, so far it only shows one or the other (example in screenshots below).
Thanks for any tips.
Untitled
You currently cannot have it both.
Plex will only pick one set of ratings (e.g. Rotten Tomatoes, IMDb or The Movie Database) – falling back to one of the other sources if the default rating for your library is not available.
Bummer. Is there a way we can make a feature request to show both / all ratings available?
Well you can by having duplicate Libraries, a workaround at best. One configured to IMBd and other Rotten Tomatoes.
You could also title Libraries Movies IMDb and Movies RT
Moved your post into the feature suggestion category.
Undid that… there’s already been a feature suggestion on that exact topic. It hasn’t gotten much attention since it’s been created – but you can comment there and add your vote.
