Showing the same vedio for all episodes of a season
Server Version#: Windows Server 2019
Player Version#: 1.31.1.6733
I have 10 episodes of a series all in one folder. When I have Plex build as part of a library it builds them all with the correct tags and such but each episode when viewed is the first episode.
I’m new to Plex, May the problem be in my naming? I have not touched the names.
They are "Showname"1, "Showname"2, "Showname"3 etc.
Thanks for any help.
Those are incorrect
https://support.plex.tv/articles/categories/your-media/naming-and-organizing-tv-shows/
Thank you, I though that may be the issue, but was not sure since the first one was fine.
Consider a renaming program.
This is free and one of the easier ones to use that I’ve found. Little to no configuration and should work fine right out of the gate. It saves a lot of time and unnecessary typing.
