Has anyone else been a little annoyed by the shuffle option when you just want your tv shows playing. Take for example I go into my Big Bang Theory folder and choose shuffle, it always seems to start playing the same few episodes right away. Same thing happens with Seinfeld. Is there any way to fix the shuffle option or can the developer tweak the shuffle algorithm to look at number of plays and last play of file? Thanks
I’ve noticed that the shuffle option now starts with the first episode that is Partially watched/Unwatched/First episode, in that order. So if you have any episodes that are partially watched, the first partially watched will start. If there no partially watched episodes, it will do the same with unwatched, then it will play the first episode.
So, whenever I want to shuffle, I click shuffle, then next. Which will actually give you a random episode (I think).
