SiliconDust - HDHomeRun Connect Quatro Tuner Support???
Does anyone know if this tuner is supported? SiliconDust - HDHomeRun Connect Quatro Tuner
Has four tuners and would be an option for me if it is supported.
Thanks…
I’d kinda be surprised if it doesn’t work already. The description at SD’s site talks about working with Plex. I hope they make an Extend with four tuners. I could simplify my setup.
I did see that, but was curious if anyone had any ideas on support. Just curious, are you using a connect or extend tuner? Would an extend be more reliable when recording multiple streams. It makes sense that an extend would be less overhead. Thanks…
I’ve got the Extend. It’s been very reliable. Offloads the transcoding to h264 from the server. Both SD and HD recordings look good when played back. I have no complaints.
